The Apalis T30 product group is end-of-life (EOL). For further details please check the revision history of the product and the related PCN. Customers using end-of-life (EOL) Tegra products are advised to use our migration guide to seamlessly migrate to recommended hardware and software solutions for their products.
For a direct replacement, Toradex recommends the Apalis iMX6, Apalis iMX8 product group or a transition to the Verdin product family.
하이라이트
Powered by NVIDIA: Tegra 3 Quad Core Processor
The Apalis T30 is a small form-factor Computer on Module based on the NVIDIA© Tegra 3 SoC. The Cortex A9 quad core CPU offers an operational frequency up to 1.4 GHz. The module offers high performance and advanced graphic capabilities at optimal power consumption. The module also exposes wide range of high-speed and advanced interfaces such as Gbit Ethernet, PCIe, SATA and many more.
The integrated NVIDIA Graphics enables visually rich, smooth and fast user interfaces.
Supreme Graphics Performance for Demanding Applications
The Apalis T30 module targets a wide range of applications, including: Digital Signage, Medical Devices, Navigation, HMIs, Avionics, Entertainment System, Thin Clients, Robotics, Gaming and many more.
It offers a wide range of interfaces from simple GPIOs, industry standard I2C, SPI, UART, to advanced interfaces such as Gbit Ethernet, PCIe, SATA, etc. It also supports many multimedia interfaces including LVDS, HDMI, Digital Audio, etc.
Robust and Pin-compatible Apalis Family
Based on the valuable input of our customers and our engineers‘ in-depth industry expertise, Apalis brings to market many new technologies. Direct Breakout™ considerably simplifies routing of high speed signals on the baseboard. MXM SnapLock™ provides a unique connector mechanism for module fixation. Apalis also comes with support for ready-made passive cooling solutions for the most demanding applications.
Latest Information on Apalis T30
You can find the latest information on Apalis T30 at the Toradex Developer Center
Toradex Developer Center운영 체제
Toradex offers free support and maintenance for Windows Embedded Compact and Embedded Linux on the NVIDIA Tegra 3 processor based Colibri and Apalis T30 SoMs. This allows system designers to focus the application only instead of focusing on the OS and low-level device drivers. Other OS such as Android are supported by our partners.
Windows Embedded Compact 7 and 2013 are supported on both Colibri and Apalis T30. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio.
캐리어 보드
SBC와 캐리어 보드에 대해 자세히 알아보기액세서리
- Compatible with Apalis T30
- CSI and DSI interfaces on one connector
- Push button for Apalis T30 reset
- No special drivers required
- Atmel touch driver
