하이라이트
Equipped with NXP i.MX 7S and NXP i.MX 7D SoCs, the Arm Cortex-A7 cores are clocked at up to 1GHz, making it an ideal choice for powerful yet efficient applications.
The heterogeneous multicore architecture allows the offloading of critical hard real-time tasks to the Cortex-M4 for extremely low latency. Toradex provides tooling and FreeRTOS to simplify development. You can also use the asymmetric multicore architecture for a connected low power mode.
The NXP i.MX 7 SoC is a power-efficient processor. In addition, the Heterogeneous Multicore Processing (HMP) provided by the Cortex-M4 allows for a low-power mode where the Cortex-A7 is shutdown to greatly reduce the power consumption.
Carrier boards designed for the Colibri iMX7 are not just compatible between the three Colibri iMX7 modules—in fact, they are compatible with the complete Colibri family, including the NXP i.MX 8X, i.MX 6ULL, i.MX 6 and NVIDIA Tegra-based modules. This gives you unmatched flexibility and easy upgradability. Currently, there are eight different modules with over 20 variations available. To make carrier board design as easy as possible, we provide the Toradex Pinout Designer Tool.
운영 체제
Toradex offers free support and maintenance for Embedded Linux and Windows CE on the Colibri iMX7 SoMs. This allows system designers to focus on the application instead of focusing on the OS and low-level device drivers. Other OS such as Android are supported by our partners.
Windows Embedded Compact 7 and 2013 is supported on Colibri iMX7. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio.
Toradex enables NXP’s FreeRTOS on Colibri iMX7. FreeRTOS is a real-time OS that runs on the Cortex-M4 core in parallel to the main OS.
Android on Colibri iMX7 is supported by our service partner Kynetics. An evaluation BSP is provided free of charge as a binary installer directly on Toradex Easy Installer feeds.
특징
CPU Name | NXP® i.MX 7 |
CPU Type | 2x Arm®Cortex®-A7 |
Microcontroller | 1x Arm®Cortex®-M4F |
CPU Clock | up to 1 GHz (A7) 200 MHz (M4) |
Floating Point Unit | VFPv4-D32 |
Arm® Neon™ | Yes |
L1 Instruction Cache | 32KB (A7) 16KB (M4) |
L1 Data Cache | 32KB (A7) 16KB (M4) |
L2 Cache | 512KB (A7) |
RAM | Up to 1GB DDR3L (32 bit) |
Flash | Up to 4GB eMMC |
USB 2.0 | 1x Host / 1x OTG |
Ethernet | 10/100 MBit/s (+2nd RGMII/RMII/MII) |
External Memory Bus | 1x 16 bit multiplexed |
I2C | 3x |
SPI | 4x |
QSPI | 2x |
SIM | 4x |
UART | 7x |
PWM | 20x |
GPIO | 126x |
Analog Input | 4x |
SDIO/SD/MMC | 2x |
CAN | 2x |
Display Controller | Single |
Graphics Controller | Integrated |
RGB | 1920 x 1080 x 24bpp |
Resistive Touch | 4-wire |
Parallel LCD | 1x |
Digital Audio | 2x SAI: I2S or AC97 |
Analog Audio Mic in | 1x |
Camera Parallel Interface | 1x 8/10/16/24 Bit |
Size | 67.6 x 36.7 x 6.2 mm |
Temperature | -20° to 85° C |
Power Dissipation | 0.6 - ~1.1 W |
Colibri iMX7 Dual
1GBPN: 0039
A7
A7
M4F
1GB RAM
4GB FLASH
-20° to 85° C
Colibri iMX7 Dual
512MB (WinEC)PN: 0033
A7
A7
M4F
512MB RAM
512MB FLASH
-20° to 85° C
Colibri iMX7 Dual
512MBPN: 0081
A7
A7
M4F
512MB RAM
512MB FLASH
-20° to 85° C
최적의 SoM을 선택하는 데 도와주세요
안내해주세요Get Started
Colibri iMX7 Evaluation Kit
US$515.45
- Two Cortex-A7 1 GHz processor
- One Cortex-M4 200 MHz processor
- NXP i.MX 7 applications processor
- Parallel RGB LCD up to 1920 x 1080 x 18bpp
Colibri iMX7 Evaluation Kit 2
US$336.45
캐리어 보드
SBC와 캐리어 보드에 대해 자세히 알아보기액세서리
- No special drivers required
- Atmel touch driver
생태계
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your on Colibri iMX7 and choose an OS!
Colibri iMX7 does not have a GPU. Nevertheless, choosing a GUI framework that supports optimized graphics on the CPU is a great choice for a modern UI with moderate level of animations. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with Crank StoryboardTotalCross
Get started with TotalcrossIndustrial Automation
CODESYS PLC IEC 61131-3
The Colibri iMX7 is a good fit for industrial automation tasks. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Colibri iMX7 perfectly.
Watch our webinar with BE.services로드맵
Hardware Roadmap
For details about the Toradex phase-over policy please refer to the PCN Policy Page.
- Q1'24
- Q2'24
- Q3'24
- Q4'24
- Q1'25
- In Development
- Sample Production
- Volume Production
Software Support Status
Latest Version
BSP
1.2b4
WEC 7 Microsoft Patch Level
September 2018
WEC 2013 Microsoft Patch Level
October 2018
Stable Version
BSP
1.1
December 2017
April 2018
Implemented Features and Software Roadmap
This list provides an overview about the most important implemented and planned software features for this product on Windows CE. The detailed feature list and roadmaps can be found on the BSP Release Details.
Ready to use
- Parallel RGB display
- USB Host (not available on Colibri iMX7S)
- SDIO / SD card
- Analog Audio Out
- Analog input
- RS485
- CAN
- SPI
- Watchdog
- RTC
- Ethernet
- USB Client
- Analog Audio In
- Resistive Touch 4-wire
- UART
- PWM
- I2C
- Multimedia playback (software)
